QO100 Live Tune with MiniTioune , No USB Found
OH6MQM
Post by OH6MQM » Sat Dec 04, 2021 8:13 pm
Hello
I would like to use Minitione with QO100 Live Tune
but while starting program (V_0_9_9_1h)
It gives error No USB device found
I did not found any configuration example
Could somebody provide correct configuration file or example ?
Br. Esko P
DG8KD
Re: QO100 Live Tune with MiniTioune , No USB Found
Post by DG8KD » Sat Dec 11, 2021 5:30 pm
latest version is j
Minitioune Package V0_9_9_1j.zip
(18 MiB) Downloaded 1030 times
Maybe an update could solve the problem.
Have you performed the check with the tools provided with the software?
Rainer
DL1BJV
Post by DL1BJV » Sat Dec 11, 2021 6:47 pm
Hello
I
It looks like the PC to which you have the MiniTiouner connected is not detecting the Minitiouner.
This could have several reasons, here a few basics to start with:
- check the MIniTiouner is working, power supply voltages etc,
- the Minitiouner USB must be plugged into the PC before starting the software,
- a bad USB cable is a common cause, try a good quality different cable,
- try a different USB port on the PC,
- you should have the 32 Bit Version of VLC installed on the PC,
- reinstall the MiniTiouner software, (I am using V1_0_1_0r Beta)
Good Luck,
Wolfgang. DL1BJV
OH6MQM
Post by OH6MQM » Sun Dec 12, 2021 10:07 am
Hello
My Case is that i do not have MiniTioune receiver. I would just like to receive from Life feed.
I that possible withbout Receiver ?
Br. Esko Petäjä
OH6MQM
Post by g0mjw » Sun Dec 12, 2021 10:48 am
No. There is no online version of a webSDR for QO100 DATV apart from streaming of repeaters, personal streams and special events. There was a system a while back. However it tends to discourage construction if reception is made too easy.
