SR DVBT LAST PORTSDOWN 2020
Patrick
Post by Patrick » Sat Dec 04, 2021 1:26 pm
Hello.
i didn't understand which SR can be used in DVBT with the latest Portsdown software.
thank you.
73 F6exx
Re: SR DVBT LAST PORTSDOWN 2020
Post by radiogareth » Sun Dec 05, 2021 8:23 am
I think the lowest DVB-T that works is 150kS, 250 and 333 are also OK. I use a TinySA to see what's coming out (or not) of my Pluto as a very handy sanity check.
Another option is V17 of ExpressDVB TX.
Post by G8GKQ » Tue Dec 07, 2021 1:41 pm
Hi Patrick
I tested Portsdown 2020 DVB-T at 250 kHz and 333 kHz bandwidths as our objective was to use this mode for weak signal operation. The lowest bandwidth that I have seen work is 150 kHz. Higher bandwidths might work, but you would need to test them.
Remeber that Portsdown 2020 only supports the LimeSDR (not the Pluto). Pluto DVB-T is supported on the Portsdown 4.
Patrick
Post by Patrick » Wed Dec 08, 2021 12:33 pm
Merci à tous
