GB3TV
Locator: IO91RU
arthur21
GB3TV
Post by arthur21 » Tue Nov 02, 2021 12:22 pm
GB3TV is currently transmitting in beacon mode on 1318.5MHz at 1m/s DVBS Mpeg2.
Reports appreciated.
73 Arthur
G4CPE
Re: GB3TV
Post by g0mjw » Sun Nov 28, 2021 11:41 am
I managed to miss this, it is MER 15-18 dB with me, D12 on 1 MS DVB-S 7/8. It might be better if it were using more FEC. I assume the plan is to use H264 and DVB-S2 eventually.
Edit, after some tweaking of preamps it is now MER22, D16. Good signal. Any plans for a receiver?
2021-11-28 (1).png (505.05 KiB) Viewed 25230 times
arthur21
Re: GB3TV
Post by arthur21 » Sun Nov 28, 2021 4:07 pm
Hi Mike
Thats great I thought it would be good in your direction. I realise the FEC is not great but the coder is an early Link C108 coder that will not let me set more FEC at 1ms/s. We do have a 70cms receiver and 23cms which both work ok but we are waiting for a logic/switcher to be worked on and then installed on site, hopefully before Christmas.
73 Arthur
G4CPE
Re: GB3TV
Post by g0mjw » Sat May 27, 2023 1:25 pm
Still there - this is my IC9700 IF.
Screenshot 2023-05-27 142310.jpg (647 KiB) Viewed 24086 times
It drops out every so often, better with less gain (down to D6) so I assume some QRM source is upsetting the tuner.
G4HTZ
Re: GB3TV
Post by G4HTZ » Sun May 28, 2023 4:02 pm
Thanks for confirming it’s on mike …I emailed the group a few weeks ago with no reply re what the working conditions were ….some of the ATV repeater groups need a serious overhaul with no updates for ages or ever …I will take a look for it next time I can get some enthusiasm… GB3PV a is a good signal here but never have seen anyone using it …same as GB3TN !!
Steve G4HTZ JO02GB52
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
M0SKM
Re: GB3TV
Post by M0SKM » Sun May 28, 2023 6:09 pm
Steve,
GB3TV is streamed fairly often at https://batc.org.uk/live/gb3tv
I understand some of the parts to update it have recently been acquired.
Pity there's no specifications or chat but I agree both would help.
Steve
G4HTZ
Re: GB3TV
Post by G4HTZ » Sun May 28, 2023 6:55 pm
Hi Steve
I’m guessing it’s just in beacon mode at present as no details of any access requirements.
I am at a new qth but main mast isn’t up yet but can RX GB3PV on a 36ele yagi at 10ft agl ..PV is about 25 miles from here .
Thanks for reply
Regards
Steve G4HTZ
Steve G3GHZ
5665 ATV FM
M0SKM
Re: GB3TV
Post by M0SKM » Mon May 29, 2023 7:43 am
Steve it's used weekday evenings; Thursday being less likely due to the QO-100 net.
There's a fortnightly net on Friday evenings, next one I believe is 09/06.
No idea why the keeper doesn't have specifications or chat, you would have to ask.
Steve
Return to “GB3TV”
