Portsdown DATV in an autonomous station
F1SSF
Post by F1SSF » Thu Aug 05, 2021 11:47 am
Hi alls,
Juste a question please, are there solutions to find stations RX or free space for TX on QO100 , actually I must use BATC spectrum, and I need computer.
Others methode or extended soft ?
73 Franck
Re: Portsdown DATV in an autonomous station
Post by g0mjw » Thu Aug 05, 2021 12:23 pm
You can use the Portsdown band viewer - https://wiki.batc.org.uk/Portsdown_Band_Viewer but if you are using that to send as well then you need to know if you have a clear channel when you transmit and as YOU ABSOLUTELY MUST MONITOR YOUR DOWNLINK at the same time as sending, so I suggest using the BATC site on a mobile phone.
F1SSF
Post by F1SSF » Thu Aug 05, 2021 2:22 pm
Thank you Mike,
this is what I do at this time, maybe a future evolution in TODO list, an integrated bandscope that will adjust the portsdown channel by simple click :)
Best 73
Franck
G7JTT
Post by G7JTT » Fri Aug 06, 2021 5:05 am
Bonjour Franck,
This may be a solution, not sure of the bandwidth that can be viewed but as long as you can monitor your chosen spot frequency it should would.
https://www.ebay.co.uk/itm/Spectrum-Ana ... 635-2958-0
73 John
F1SSF
Post by F1SSF » Fri Aug 20, 2021 1:29 pm
Hi John,
Sorry to be late, tnx for reply. I don' t sure it is good solution.
I thought rather at this script integrate in RX DATV ports down:
https://wiki.batc.org.uk/QO100_Live_Tune.
I don't know if is it possible ?
Best 73 Franck
Post by G8GKQ » Mon Aug 23, 2021 5:02 pm
Franck
Are you asking about a station with internet access, or a station without internet access?
Live Tune needs internet access.
F1SSF
Post by F1SSF » Mon Aug 23, 2021 7:01 pm
My portsdown is connected to internet.
It was just an ideas , to integrate a system similar to LiveTune, to have a compact DATV station without need a PC to see the QO100 spectrum.
Imagine you adding this, you clic on station with the tactile screen, and directly portsdowns adjust automatically. (for RX station, and free QRG for Txing).
All the best
73 Franck
Post by G8GKQ » Mon Aug 23, 2021 8:34 pm
Hi Franck
An interesting idea, but very complex to integrate.
I will think about a BandViewer style display to show the spectrum from the Goonhilly web monitor. It is not that easy because the Portsdown does not have a "Desktop Environment". Everything has to be built pixel by pixel.
F1SSF
Post by F1SSF » Tue Aug 24, 2021 5:07 am
I have forgotten this ;-).
Perharps , a basic picture where lighting segments when there is frequency activity ? Sorry I am not programmer for more help.
Happy day.
73 Franck
Capture d’écran 2021-08-24 à 06.59.07.png (10.74 KiB) Viewed 4893 times
