DATV/SSB PA For Pluto or Lime SDR
vu3obr
Post by vu3obr » Wed Jun 30, 2021 3:06 am
Hello to ALL,
I have More then 20 PCs of Nokia Surplus PA Madules for sale.
Description and Features:
1). The main application of these units is to amplify the very low output from SDR devices, Such as the Adalm Pluto or LimeSDR for QO-100 SSB/DATV.
2). 2100Mhz UMTS Module – Modified to use with 2100Mhz to 2400Mhz Ready to use Es'Hail 2 QO-100 DATV/SSB,No snowflake used,Tuned External BIAS Bard and Tested with SSB/DATV Pluto SDR and Lime SDR without Extra Predrive.
3). IN/OUT SMA Connector.
4). RCA Connector for PTT.
5). Working Voltage: 28v DC Max.
6). Power Output: 30 to 50w at QPSK and 3 to 5w SSB with Pluto/LimeSDR, No need to change BIAS for SSB/DATV, input Power Controlled by Pluto web interface or Software.
7). Used by many radio amateurs for up linking to QO-100 SSB/DATV.
8). Specification:
Dimensions (L x W x T): 240 x 100 x 20 mm
9). RF Power LDMOS
Final LDMOS: 2x AFT21S232S
Driver LDMOS: 1x BLF6G22LS-40P
Predrive: 1x SZA2044z
10). 3x Drop-in circulator with dummy load.
The Module is Ready to use
Important Notes: HEAT SINK and COOLING SYSTEM must be added.
Interested contact vu3obr@gmail.com
1pcs Price £185.00
Including Free Shipping Worldwide.
Saro
Jabi
Re: DATV/SSB PA For Pluto or Lime SDR
Post by Jabi » Wed Jul 21, 2021 6:30 am
Hola:
Soy Jabi, ea2aru y estoy muy interesado en su lineal parael QO-100. Por favor, me podría indicar que sistema de refrigeración me recomienda y que disipador de calor, para hacerme una estimación del costo total.
73,s de Jabi, ea2aru.
Jabi
Post by Jabi » Wed Sep 15, 2021 3:05 pm
What power supply recomend? 28 Volts and ??? amperes? 15A? 20 A? 30A?
Regards de Jabi, ea2aru.
vu3obr
Post by vu3obr » Tue Sep 21, 2021 1:27 am
Hello Jabi,
Hope you received details by mail.
Saro VU3OBR
EA3IBE
Post by EA3IBE » Fri Sep 24, 2021 5:07 pm
Hi Jabi, I bought to Saro one of these amplifiers, and my project consist to run with 20A P.S., and a radiator that is 2cms. bigger for each side and with 3cms. height. And also with 2 units of 10cms. fan.
vu3obr
Post by vu3obr » Wed Dec 01, 2021 2:39 am
Dear Friends,
Still i have same PA Modules available for sale.
Saro
VU3OBR
G1BVI
Post by G1BVI » Mon May 02, 2022 3:25 pm
This amplifier needs 28V @25A
Alliexpress have just let me down !!
I ordered a 28V 800W psu and it got to China customs and then got returned to sender.
Still trying to contact them for a refund.......... or a replacement.
I am looking for a cheap alternative solution and so
I wonder what others are using to power this amplifier?
Also has anyone tried combining two?
Thanks in advance
Nick
G1BVI
Post by radiogareth » Mon May 02, 2022 3:31 pm
Nick, this 'hack' will allow 28V and these PSU's are as cheap as chips on eBay. Just be careful, 400VDC inside!!
You have to isolate the PCB on the 'higher' one and set them both to 14V. I'm changing the caps on mine to 25V units 'just in case'.
https://www.youtube.com/watch?v=9--g63ew9HU
Gareth (yet to try this particular mod....)
G1BVI
Post by G1BVI » Mon May 02, 2022 4:39 pm
hi Gareth.
Thanks for that.
The mod shown works and is used to increase a 12v psu to 13.6 or 13.8v.
You cannot go higher than about 15 volts because the electrolytic caps are only rated at 16v or so.
I probably need to find a 32v psu at 800w that I can reduce down to 28v..
There are plenty of these amps out thereeeing .
I remember about a month back seeing them mentioned on qo100 ie station using ......
But did not note callsign.
Nick
Post by g0mjw » Mon May 02, 2022 4:56 pm
Why not just use one of the Dutch 28V ex-telecom PSUs ? They were on ebay from tautronix and I see they still are as item https://www.ebay.co.uk/itm/175080996660 the postage is a bit high but order several units and it won't be so bad.
