WinterHill parts
PA3CX
WinterHill parts
Post by PA3CX » Tue Jun 22, 2021 7:48 am
Hello Forum members,
Still looking for some part for my Winterhill.
Found stock on Farnell but i'm not able to order.
28C0236-0JW-10 - Ferrite Bead, Axial Leaded, 998 ohm, 5 A, 0.01 ohm Fabrikant: LAIRD
240-2493-ND
i need 4 of these.
None stock on digikey and farnell,
MIC29300-12WT - LDO Voltage Regulator - Fixed, 26V input, 12Vnom/3 A out, TO-220-3
576-1118-ND
i need 1
Any members have these spare in the shack and willing to sell them ?
Best regards
ramon
M5TXJ
Re: WinterHill parts
Post by M5TXJ » Wed Jun 23, 2021 8:05 am
The same inductor, but without the little plastic spacer on the leads is in stock at Digikey. 240-2492-ND
I got my MIC29300 from RS, theyre only available in twos and there are only six in stock, my spare went to another builder.
73 Dave.
DG8KD
Post by DG8KD » Wed Jun 23, 2021 4:49 pm
Hi Ramon,
I still have 4 of those available here:
Got them at Mouser
Rainer
PA3CX
Post by PA3CX » Thu Jun 24, 2021 5:14 am
Thank you for the feedback !
Rainer, ill pm you for more info.
73' ramon
g7kpm
Post by g7kpm » Thu Jun 24, 2021 6:50 pm
I have used these on my RX from Mainline Electronics. I threaded the adjacent wire through the vacant hole to enable it to be mounted vertically and they seem to work OK as a substitute for the out of stock Digikey 240-2493-ND
eBay item number: 292517277490
£4.50 for 5
73s Jason G7KPM
g7kpm
Post by g7kpm » Thu Jun 24, 2021 7:04 pm
MIC29300-12WT
https://www.aliexpress.com/item/1005001 ... e291c4e5-0
$13.50 USD for 10
73s Jason G7KPM
