Wideband FM?
Wideband FM?
I know Langstone is intended for narrowband modes. Might it easily be extended for domestic wideband FM stations? They are handy for sound tests.
73 Graham
73 Graham
Re: Wideband FM?
Think I asked that a while back and got a 'no plans' answer. Fairly sure the Portsdown supports the RTL dongle for that sort of usage.....
Re: Wideband FM?
Langstone uses 48KHz sampling for generating and receiving all modes. That is not high enough to handle wideband FM. Increasing the sampling rate would put extra processing load on the Pi which is already working quite hard.
Re: Wideband FM?
Portsdown 4 has it on Menu 2, RTL-FM RX, just tested it on local FM station. OK so you need a £10 RTL dongle....
|Gareth
|Gareth
Re: Wideband FM?
OK Colin, all noted. 73 Graham
Re: Wideband FM?
I hadn't paid attention to the PD4's RTL-FM button, so thaks for the reminder Gareth. I have an RTL dongle somewhere.radiogareth wrote: ↑Mon Jun 21, 2021 4:44 pmPortsdown 4 has it on Menu 2, RTL-FM RX, just tested it on local FM station. OK so you need a £10 RTL dongle....
|Gareth
73 Graham
