Differentiated band switching frequencies > 23cm?
DL5BCA
Post by DL5BCA » Thu Jun 17, 2021 5:34 pm
is it not possible to do a differentiated band switch (for LNA and/or PA) with frequencies > 23cm with the Portsdown, like Langstone?
I always have crazy ideas.
Please don't be surprised.
Re: Differentiated band switching frequencies > 23cm?
Post by G8GKQ » Thu Jun 17, 2021 6:54 pm
DL5BCA
Post by DL5BCA » Thu Jun 17, 2021 7:14 pm
Hello Dave,
Thank you for the answer
automatic only 4 status, by output MSB LSB.
I think i have to use a MCP23017.
I will test at next weekend.
DL5BCA
Post by DL5BCA » Fri Jun 18, 2021 11:03 am
Do I have to activate it in portsdown to control the MCP23017?
It works at the Langstone.
Post by radiogareth » Fri Jun 18, 2021 12:46 pm
From memory, I think I had to do it from the RPI dashboard via SSH....
I got it working and tested, but I have not used it so far and the card has been rebuilt since. Not sure if its retained in the RPi or on the card...
Gareth.
Post by G8GKQ » Fri Jun 18, 2021 9:14 pm
Hi Robert
There are 3 switching lines (the transverter line is used as the 3rd), so 8 combinations are available. I am working on increasing this to 4 lines for 16 combinations.
Control of the MCP23017 is not supported by Portsdown.
DL5BCA
Post by DL5BCA » Sat Jun 19, 2021 7:57 am
MCP23017: Then I misunderstood that. I understood it that way, because only 3 lines are available, an I2c expander was chosen as an alternative.
Now a good 8 possibilities are enough.
Can I set the signals myself, or are they fixed?
Post by G8GKQ » Sat Jun 19, 2021 10:40 am
Hi Thomas
You can force the 3 outputs to your own settings by setting them in [Menu 3], [Band Settings], [Desired Band], [Express and Lime Port Settings] to numbers above 16:
16: 000
17: 001
23: 111
The script that does this is here: https://github.com/davecrump/portsdown4 ... er.sh#L139
I am currently revising all of the band switching so this will change soon, but there will be some backwards comapatibility.
DL5BCA
Post by DL5BCA » Sat Jun 19, 2021 4:30 pm
Thank you for the information Dave.
