How might this POTY antenna work for RX with no LNB?
Basil
Post by Basil » Wed May 19, 2021 9:34 am
I am slowly getting into amateur satellite work and run a 1.8 meter prime focus dish with a POTY antenna for 2.4GHz TX and a coaxial LNB for circa 10.5GHz reception. I know the LNB down converts to around 940 MHz using an intermediate frequency.
I heard a very nice SSB signal from a chap who appeared to know a lot about the hardware used, so looked him up on qrz.com He was using a POTY antenna the like of which I have not seen before. It has a feed horn and appears to feed the RX side without an LNB directly to a Kuhne down converter. How might that work, I thought down converters expected a lot of gain from the LNB and an already down converted signal, to some extent, done within the LNB?
I placed a photo of this nicely looking engineered device here:
http://www.chriswilson.tv/DJ8EI.JPG
It appears there's no LNB but the RX antenna is inside the POTY tube itself??
Chris 2E0ILY
Best regards,
Re: How might this POTY antenna work for RX with no LNB?
Post by G8GKQ » Wed May 19, 2021 10:31 am
Chris
Remember that this setup is for SSB, not DATV.
There is a probe picking up the signal from the central circular waveguide and taking it to the input of the Kuhne LNB/downconverter. Kuhne LNBs have similar noise figures to domestic satellite LNBs, but less gain. However, for SSB, the receiver in use is a lot more sensitive than a TV satellite tuner, so less gain is required.
For DATV every dB matters. For SSB, you can afford to lose a few dB both on the transmit side and the receive side. So read-across from SSB "experts" to DATV should be treated with caution.
Basil
Post by Basil » Wed May 19, 2021 10:38 am
Ah, OK, thanks for the nice explanation Dave, I was mainly wondering if indeed the tube had a probe like inside a normal LNB, but didn't understand how they then increased the signal level from the probe to the Kuhne convreter. If the converter has extra amplification compared to a more generic one, that explains how it works very nicely, thank you!
So for DATV what is considered the optimum DATV RX antenna these days, a generic LNB perhaps modified for accepting an external reference, or are there speciality ones around? Thanks.
Best regards,
Post by radiogareth » Wed May 19, 2021 10:51 am
The 'Bullseye' LNB is good enough for SSB out of the box and has very good 'ears' from what I can tell, slightly up on an Octagon for instance...
Sadly seems it needs buying form the EU....so brace yourself for the shipping charges....https://www.passion-radio.com/lnb-pll/l ... t-978.html
Post by g0mjw » Wed May 19, 2021 3:01 pm
The Bullseye is also available from RTL SDR via Ali-Express. https://www.aliexpress.com/item/4001089 ... f0511oEvuR
They charge VAT at source so expect it to cost about £26.
Basil
Post by Basil » Thu May 20, 2021 10:39 am
Thanks, I have a Bulls Eye LNB and am also experimenting with a ready modded LNB from qro.cz that can be locked to a 25MHz reference up the one RX coax to the LNB. It seems to work well, but there seems to be a frequency offset. I have, in the below the dish cabinet, a Leo Bodnar GPSDO with 2 outputs. One at 40MHz is an external reference to my PlutoSDR, and one at 10MHz that goes to the qro.cz combined injection and BiasT. Inside this box from qro.cz I assume there's some form of multiplication up to 25 MHz. There's certainly a chip in there.
However, in use, whilst TX frequency is perfect, (measured with a GPS locked, in calibration frequency meter), the RX is off a tad, compared to the QO-100 beacons. I am not sure why and am currently using SDR Console's Geostationary Beacon locking ability. I had expected locking the LNB LO to a GPSDO would not require this, am I missing something here please?
Apologies for misusing the term POTY before, I am getting better as I frequently typed it as POTI for ages :)
Thanks for the help. 2E0ILY
Best regards,
