GB3CT on air
g7kpm
GB3CT on air
Post by g7kpm » Wed May 12, 2021 7:27 pm
GB3CT is now transmitting on 3404Mhz DVB-S2 1M/s from IO93UM, Caistor Top, Lincolnshire Wolds.
No receivers are currently active, beacon mode only.
Any coverage reports would be appreciated.
73s, Jason G7KPM
Re: GB3CT on air
Post by M0DTS » Thu May 13, 2021 9:51 am
Couple of screenshots of paths i tested yesterday.
IO94JF Sutton Bank was fine with a little qsb, up to D4.
path IO94JF.JPG (121.91 KiB) Viewed 4981 times
IO94LI Cockayne Ridge was about 2dB over the noise so a little weak to decode, another 2-3dB may just have done it.
Interesting that the path plot suggests it should be nearly 20dB worse there.
path IO94LI.JPG (128.82 KiB) Viewed 4981 times
m1cdq
Re: GB3CT on air
Post by m1cdq » Thu May 13, 2021 12:09 pm
Rob out of curiosity what is your rx set up
Re: GB3CT on air
Post by M0DTS » Thu May 13, 2021 2:09 pm
It's an 80cm Dish with a C-band LNB (C1W-PLL type) at the feed point.
Unfortunately those LNB's are not as easy to come by, the non PLL ones are easier to get and do also work for 1Ms signals but you have to be careful of any LO offset.
Re: GB3CT on air
Post by M0DTS » Thu May 13, 2021 2:15 pm
Now i've looked at the photo i took of the dish pointing to CT i think i may have been on a vertical lobe as the dish looks to be pointing very low!!
This will explain whey there was not as much signal difference between the two sites as predicted.
I'll confirm this next time i'm at the site.
Dish to CT.jpg (211.97 KiB) Viewed 4935 times
g7kpm
Re: GB3CT on air
Post by g7kpm » Fri May 14, 2021 9:59 pm
Thankyou for the report Rob, it's good to see that the repeater is getting out OK.
Much appreciated.
73s Jason G7KPM
