Portsdown PTT delay adjustment
HB9IAM
Post by HB9IAM » Thu Apr 29, 2021 10:45 pm
My TRX DATV composed of Portsdown 4 v 202104250 and Pluto with an Arduino sequencer to control the power supply
for the antenna preamplifier, the antenna coaxial relay and the PTT of the PA.
Therefore the 8 seconds delay is not useful, can you tell me the line of code necessary to adjust this timining between 500 mS and 2S?
Thank you,
73's Pierre HB9IAM
Re: Portsdown PTT delay adjustment
Post by G8GKQ » Sat May 01, 2021 3:57 pm
HB9IAM
Post by HB9IAM » Thu May 06, 2021 5:04 pm
Thanks Dave for your answer - the minimum achievable time is 2 seconds, ok for my application !
73 Pierre
IZ7PDX
Post by IZ7PDX » Tue Dec 06, 2022 5:12 pm
I just now noticed this interesting discussion.
Dave could you tell me if to activate a delay in PD4 it is necessary to act on some command or just modify this command line? If you wanted to have a programmable key with different timings in the PD4 menu that would be great. Do you think it's possible?
