GB3GG is now transmitting on 1310Mhz DVB-S2 digital TV with a symbol rate of 1Ms
Locator: IO93XM
TX: 2420Mhz
RX1: 1280Mhz
RX2: 2388Mhz
RX3: 10.315Ghz
RX4: video over IP webstream controlled via DTMF menu (currently on 144.750Mhz)
Echolink talkback (sort of working but still being worked on time permitting)
1x Roof camera
1x Room camera
144.750Mhz talkback relay on TX via 6.5Mhz subcarrier
Website: http://www.gb3gg.org.uk
Webstream with chat: http://www.batc.tv/ch_live.php?ch=2&id=6
Activity: Mostly Friday evenings from 20:00 till late!
m1cdq
Post by m1cdq » Sun Apr 25, 2021 2:27 pm
Coverage of N E lincs seems good but any reception reports are greatfully received.
g7kpm
Re: GB3GG is now transmitting on 1310Mhz DVB-S2 digital TV with a symbol rate of 1Ms
Post by g7kpm » Sun Apr 25, 2021 10:15 pm
Beacon only mode. Rx not yet active.
g7kpm
Post by g7kpm » Mon Apr 26, 2021 4:21 pm
Rx active:
1280MHz FM Analogue
Post by G3GJA » Tue Apr 27, 2021 9:03 pm
Received in Anlaby Common, west of Hull city centre at D3. Distance is 29.8km. Radio Mobile plot attached.
Had to use my GB3EY look-through filter in front of the Minitioune to keep the Claxby radar out of the front-end.
Congratulations on getting it operational.
73, Clive G3GJA / G8EQZ
GB3GG Radio Mobile Online.pdf
(633.51 KiB) Downloaded 1052 times
G0ATW
Post by G0ATW » Wed Apr 28, 2021 9:22 am
Thanks for the report Clive it's good to be back on the air and surprised at the coverage reports.
Our aerials are only 40 foot above sea level we only expected coverage of N E Lincolnshire.
The good news is that with the extra interest generated some locals are finding that they can receive EY as well.
73s John G0ATW.
M1ASR
Post by M1ASR » Wed Apr 28, 2021 10:33 pm
I nearly got a lock in Skipsea, Ryde was trying very hard! My QTH is @ 6m ASL, Antenna @ 16m. Will try again tomorrow.
73, M1ASR
m1cdq
Post by m1cdq » Thu Apr 29, 2021 6:30 am
cheers for the report M1ASR
what antenna with or without preamp
the repeater is getting out better than expected.
hope you manage to get a lock
cheers roger M1CDQ
M1ASR
Post by M1ASR » Thu Apr 29, 2021 1:52 pm
Hi Roger,
Antenna WIMO 44e - 18.1db
Preamp - RF Design G8FEK
Rx - MiniTioune/Ryde Combo
Locator - IO93VX
I'll keep trying!
Regards
73 Graham M1ASR
Post by M0DTS » Sat May 01, 2021 4:59 pm
GG is getting out well on 1310MHz.
I received it while out portable today from IO94LI on the Moors north of Helmsley, that's 114KM!
Stable signal D2-D4.
Tried access on 1280 FM but no luck, shows how well the narrowband digital is working.
Screenshot and path plot below, you can see EY off beam on the sdr plot too. VL is 2MHz wide and was just noticeable with qsb too.
1310 is an interesting choice (or there was no options) so near to VL but it works well!
System: 2x28el loopyagi, LNA 0.8dB NF, Tx 80W FM.
Screenshot (150).jpg (123.37 KiB) Viewed 21523 times
sdr GG_EY.png (261.88 KiB) Viewed 21523 times
m1cdq
Post by m1cdq » Sat May 01, 2021 5:35 pm
cheers for the report. I'm well impressed how well GG is getting out and im sure John G0ATW is as well.
Return to “GB3GG”
