LNB supply PCB
g7ntg
LNB supply PCB
Post by g7ntg » Thu Apr 22, 2021 5:45 pm
Any Idea when the LNB supply PCB will be back in the shop?
Will I be able to buy 2?
Re: LNB supply PCB
Post by g0mjw » Thu Apr 22, 2021 6:08 pm
They are on order Jim, Noel is expecting them next week I understand.
Why do you need two? The design allows for up to two optional LNB boards. They are not required if you don't need an LNB supply and quite unlikely most people will need more than two LNBs, not even in Greece.
G1BVI
Re: LNB supply PCB
Post by G1BVI » Wed May 19, 2021 11:01 am
Do not fall into the trap I just find myself
I went through WinterHill BOM and ordered all parts from Digikey.
I ordered the Advanced Receiver PCB which clearly states that the SMDs are not included.
I also ordered a LNB Supply PCB that is pictured fully populated and makes no reference to only being a PCB
I guess I was naive in assuming it was an OTS Module, as I received a blank PCB.
Delving deeper into the forum pages I found the BOM etc.
I will have to order bits from somewhere but mention it as a warning to others not to be an idiot like me :-)
Nick
G1BVI
DL1BJV
Re: LNB supply PCB
Post by DL1BJV » Wed May 19, 2021 8:30 pm
Hi Nick,
that was my first thought too. But when I saw the price of the PCB 3.50GBP it was obvious that it was for the unpopulated
Board. The price for the componants alone add up to about $18 when ordering from Digi-Key.
I have attached a link below which has all of the parts listed, including layout and circuit diagram.
viewtopic.php?f=136&t=7275&start=10#p26881
Just click on the message from G0LJF ... RT_Module_Farnell.xlsx file.
73 Wolfgang
G1BVI
Re: LNB supply PCB
Post by G1BVI » Sun May 23, 2021 5:22 pm
Thanks Wolfgang
Bits from digi key not here yet, waiting on 1 part !!
Now I see the BOM I see what you mean, just did not give it any thought hi hi
Nick
