Portsdown at 4000 kS.
VK3BVR
Post by VK3BVR » Tue Apr 13, 2021 11:20 pm
Dave,
I notice in the Pluto Wiki you mention that you have seen Portsdown 4 working at 1000 kS.
Thought you'd like to know that in Melbourne several stations are using it into the local repeater without any problems at 4000 kS.
Bob,
VK3BVR.
vk3zsj
Re: Portsdown at 4000 kS.
Post by vk3zsj » Wed May 05, 2021 9:03 am
Hi Bob.
I just got mine fired up yesterday. Portsdown4 and Pluto. A lot of learning in from of me yet!!
I can get mine sending the image of the portsdown touchscreen at 4000 KS. Using 1255 Mhz across the room.
I could only get DVB-S to work at 4000 KS. I can make DVB-S2 work at 2000 KS with QPSK. Have you had any success with DVB-S2 above 2000 KS? I note my transmissions were of a static image of my touch screen, no fast moving images.
thanks
Simon VK3ZSJ
Post by G8GKQ » Wed May 05, 2021 10:04 am
Simon
As mentioned here https://wiki.batc.org.uk/Portsdown_4_Pluto the Portsdown is only tested with Pluto up to 1000 kS. The whole design is optimised for low symbol rates, not the higher SRs that you are using. For those, the optimum configuration is to use a LimeSDR Mini in LimeDVB mode.
VK3BVR
Post by VK3BVR » Wed May 05, 2021 11:08 am
Hi Simon,
Mine is the same as yours in that it only works at 4000 ks with DVB-S and is just a lucky that is useful to us with VK3RPTV .
Dave's explanation is a far more detailed and accurate explanation than I could give as to the bigger picture.
Regards,
Bob.
VK3BVR.
