OLED Display issue
G1LWX
OLED Display issue
Post by G1LWX » Tue Apr 06, 2021 8:53 pm
Hi I have just fitted an Oled display to my minitiouner V2
It works fine but when I switch off the minitiouner the Oled display stays on
I have taken the supply for the Oled from J2.
Only when I remove the usb connection does the display switch off is this normal as no one seems to have commented.
Mike G1LWX
Re: OLED Display issue
Post by g0mjw » Tue Apr 06, 2021 9:03 pm
Yes. Take from the other 3.3V supply if you want it to power off with the 12V. You currently have it running off the 3.3V FTDI module regulator.
G1LWX
Post by G1LWX » Wed Apr 07, 2021 7:51 am
Thank's Mike
All ok now
OE8PCK
Post by OE8PCK » Sat Oct 15, 2022 4:31 pm
Mike G1LWX
Hi Mike, Could you be so kind as to show me the connections for the Oled including any info I would need to run it. Can I use a 2 inch Oled screen too or must it be thee 1 inch type?
Many thnks in advance.
73 de Paul OE8PCK
Post by g0mjw » Sun Oct 16, 2022 9:00 am
Hi Paul,
If you look at the minitiouner.ini file it will tell you what OLEDs are supported. It has been a long time since I looked at this but I think there is a larger version supported. There is also a large TFT supported by the Pro2. I don't know if that works with the minitiouner v2. It might, but the screen is too large to fit the standard box front panel.
The connections needed are 3.3V, Ground, I2C Clock and I2C data. This was covered in CQTV but can I find it? I will look.
Note, although it seems like a good idea, in practice I never found a use for it as it tells you what you already see on the screen. If you had a remote system, where the tuner was far from the screen, e.g. a repeater, then this would be useful, but most of us are looking at the screen to see the images.
Edit - from the config file, looks like a 2.2, 2.4 and 2.6 inch display is supported. The 2.6 is I think the TFT. You will have to trawl the posts from JP to get the model number, the display doesn't seem to be covered in the PDF manual which comes with the full version.
[Display]
; OLED 1.3" : yes or no
; Digole 1.44" or 1.88" => Digole=14 // Digole 2.2" or 2.4" => Digole=22 // 2.6" => Digole=26 // NO Digole => Digole=0
OLED=yes
Digole=26
LCD=0
Post by radiogareth » Sun Oct 16, 2022 9:12 am
And if you use a Portsdown or Ryde as your RX its redundant anyway.....
I liked it when I used MT on the PC though.....
OE8PCK
Post by OE8PCK » Mon Oct 17, 2022 8:43 am
Many thanks for your kind help. Worked first time :D
I was lucky!!!
