Fan
G0LJF
Fan
Post by G0LJF » Thu Mar 25, 2021 10:28 am
There is the option (I read) of a fan.
Now looking at the PCB and measuring the PCB PNG holes and scaling, together with the suggested RPi4 spacer length of 20 mm leads me to have assumed a 40 mm fan with about a 10 mm thickness. Much more and it raises the RPi off the 40 way header that is about 16 mm in depth.
Now the BOM does mention using a dropper resistor for various fan voltages so I am guessing, again, in the range of 5V to 12 V.
Perhaps a little size clarity would help so the fixing holes may line up.
I took the plunge and went for a 40 mm 12 V one on 32 mm square fixings.
I maybe wrong...
Addendum: I missed this snippet "providing clearance for a 40x40x10mm fan". So perhaps someone else will too. I think a BOM entry would help.
73, Mike
Re: Fan
Post by G4EWJ » Thu Mar 25, 2021 12:18 pm
G0MJW is looking after the pcb, so I'll let him give the definitive answer on fan sizing.
The fan supply on J3 is 12v through R1, so a 12v fan with a resistor to modify the speed should be fine. R1 is 2512 size, but I expect 2 x 1206 size resistors in series would work.
5v, without a series resistor, is available on JP4, just to the east of the 3 psu modules.
G0LJF
Re: Fan
Post by G0LJF » Thu Mar 25, 2021 12:38 pm
Thanks Brian,
All noted. Just got some parts today, including 40 mm X 10 mm fan, part number 281-6685 from Farnell.
Its really a matter just to add a BOM line item [reminder] with the definite fixing hole size so anyone can order one that screws in OK.
Otherwise there maybe a mechanical problem.
Thanks, Mike
Re: Fan
Post by g0mjw » Thu Mar 25, 2021 4:28 pm
Winterhill is an advanced project with decisions like the casing and cooling left largely to the builder. We assume a fairly high level of construction experience. The solutions can be shared and added to the Wiki over time.
The PCB fan, if fitted, is indeed a 40mmx40mmx10mm standard 12V fan. The dropper resistor is needed to slow it down, both in order to keep the operator sane, and to account for 13.8V supply if used. I used 100R and it was fine, but fans vary in their current ratings. The reason a specific fan is not on the BOM is I have not bought one, so I don't know what to choose.
This is not the only option. A case fan could be used, it depends on how you box it and how you cool the PI. My first prototype used a heatsink case for the PI and the fan just ensures airflow in the repurposed set top box it resides in. I will post some pictures of how I have done it.
G0LJF
Re: Fan
Post by G0LJF » Thu Mar 25, 2021 5:27 pm
Fine by me,
Thanks for the information.
My comments are based on the ease of a simple translation from BOM to an order, and not having items in the BOM meant I was missing a couple of items. I like to order up all the components in advance (of the disappointment in missing something important later).
And the fan [if used] has to fit into the PCB as supplied - and the mounting holes are 32 mm square. But this is not specified.
Thanks for the update, I am still waiting for the BATC order and Farnell but have built the SD card already. The software instructions provided made that easy, ta.
73, Mike
