PLUTO for TX and RX
EA7KIR
PLUTO for TX and RX
Post by EA7KIR » Mon Mar 15, 2021 5:51 pm
Can a PLUTO be used with the DATV QO-100 uplink and downlink frequencies at the same time (duplex) ?
Michael EA7KIR
Re: PLUTO for TX and RX
Post by g0mjw » Mon Mar 15, 2021 6:31 pm
Yes. SDRConsole does it. However you could have googled that, and so wouldn't ask. A assume you mean for DATV. I don't think so as the USB bandwidth is not so high.
EA7KIR
Post by EA7KIR » Mon Mar 15, 2021 8:49 pm
Indeed I do mean DATV. That's why I said so when asking for help. I've been Googling all sorts of things for weeks, including SDRConsole, because there's nothing in this forum or the WiKi. So far, I haven't found any talk of this relating to DATV. That's why I've resorted to asking on this forum. So, if anyone, or knows of anyone, who has knowledge of using a PLUO for QO-100 DATV in this way, I'd love to hear of their experience.
Michael EA7KIR
Post by G8GKQ » Mon Mar 15, 2021 9:01 pm
Michael
I'm not sure exactly what your question is.
You can use the Pluto for DATV Transmit to QO-100 either using the BATC Portsdown Transmitter, or by using a PC and more recent versions of the F5OEO software. There is plenty of information on the BATC Wiki about that.
However, there is no accompanying receiver using the Pluto. Or at least not one that will receive at the same time as using the Pluto for DATV Transmit.
It would be possible to use the Pluto as a DATV Receiver, but there are much better solutions using the MiniTiouner family of hardware.
Post by g0mjw » Mon Mar 15, 2021 9:11 pm
So as I said. I tried to get the software decoder to work (both SDR Angel and the later one that uses Limes and RT dongles) but I didn't manage it. You might get somewhere with Gnuradio but the problem is the USB2 limitations so it is only going to work at low SRs. Gnuradio TX is simple enough. RX a bit more diffucult.
Post by radiogareth » Tue Mar 16, 2021 8:54 am
I have had some success with the Amsat DVBSGUI software (it will reliably decode the beacon for me using RTL, RSP1 and Pluto as receiver) but it is very flakey in its behaviour. SOmetimes almost instant lock, other times, it just won't go.Better than nothing but certainly not plug and play. Similar to SDRAngel, works sometimes, not others. Main problem for me is getting it to see what I have plugged in. I now use a Ryde and the IR 'mute' button for DATV via QO-100.
Pa3fbx
Post by Pa3fbx » Sat Mar 20, 2021 9:02 pm
well, i had to try and yesss....
It is posible to use the pluto with dvb_gui to see the beacon and use OBS to resend this received stream back to the sat via the same Pluto...
Pluto is connected via USB and connected to LNB and amplifier.
Bare in mind you are running 2 different heavy duty programs on same computer, so that part need very high CPU capabilities..
and DVB-Gui is a bitch to get a nice picture..
But yes, you can use 1 Pluto with P5OEO firmware, OBS, DVB-Gui to full duplex DATV...
Best regards
Benno
Return to “Getting Started?”
