Where are the red longmire screens created
Pa3fbx
Post by Pa3fbx » Wed Mar 10, 2021 3:40 pm
Today a new question as i wasn,t able to figure out myselves..
I wonder if i would be able to get a different image on the display when the ryde is not receiving anything..
Preferably a Jpeg or even a foto library but anything else than that nasty red screen...
Any idea how this could be done..
Best regards
Benno
MW0RUD
Re: Where are the red longmire screens created
Post by MW0RUD » Wed Mar 10, 2021 3:51 pm
Hi Benno,
It is rendered on the fly in states/playback.py based on the system state.
There is already an issue open about adding more options for that screen but it is not a high priority: https://github.com/eclispe/rydeplayer/issues/44
Tim
g8lce
Post by g8lce » Wed Mar 10, 2021 4:57 pm
You could use the received signal output GPIO pin to switch the video output to something else.
I have written a python program for an arduino that controls relays using the GPIO received signal pin. This works with upto 4 Rydes and selects a quad output if more than one RX signal. I also put in some code that safely turns the RPis off and back on when needed.
This is for GB3NQ in the future.
Arduinos and relay boards are cheap and you could even switch the HDMI signal with enough relays! 16 on a cheap board.
Martin G8LCE
