2022 Activity and Contest dates
Post by G3GJA » Fri Mar 05, 2021 9:37 am
The BATC is holding twelve Activity Weekends, spaced at four week (+/-) intervals during 2022. The Weekends are aligned with the IARU contest in June and the Veron Activity Weekends that our Dutch friends are holding in March, June, September and December.
For 2022, the weekends will focus on three groups of bands on a repeating rota. Starting with January, the focus will be on 70cms. In February the 2m, 4m and 6m bands will be used, followed by March with 23cms and higher bands. That will then repeat for subsequent months in the same order, with June being skipped as that is the all-band IARU contest weekend. To ensure that all stations can get some activity, optionally 23cms can be used on every Activity Weekend during 2022.
Here is the calendar:
Calendar 2022.jpg (77.75 KiB) Viewed 7165 times
As usual, there are no set times for operating, although you should be aware that stations taking part in the Veron Activity Weekends operate from Saturday 12:00 UTC until Sunday 18:00 UTC.
Please try to make use of the DXSpot.TV website to find activity. The Dutch ATV stations have used it more than British ATVers clearly showing it helps to find ATV activity and set up contacts. The website is here: DxSpot.TV and is easy to use.
Clive G3GJA
