yesterday I updated my Ryde receiver via the menu with the development version.
Ryde seems to run very well after the update, QO-100 runs for about an hour or one and a half in the background.
Then I saw, that the screen suddenly shows the console. I logged in via SSH and started thge receiver and it runs normally.
I rebooted from the console and Ryde starts up normally.
Today the same. After about one and a half hour the receiver quits and the console appeared.
Any ideas? Is there a special log I can take a look at (syslog and dmesg doesn't show no anomaly).
Maybe it has to do with the latest OS updates, I think there wasn't much activity at the receiver itself...
Thank you.
73, Thorsten
Strange Ryde shutdowns since latest updates...
Re: Strange Ryde shutdowns since latest updates...
Hi Thorsten
Using a Dev release is not a good idea unless you have been specifically notified that it is ready for testing. Quite often it is in a broken state while I build something that works. On this occasion the Dev release has been stable since 25 Jan, and is identical to the current production release.
I did an update on my test system this afternoon, so it is at the latest standard of operating system and Ryde updates. It has now been displaying the beacon continuously for 4 hours with no problems. So I do not know what is causing your problem.
You can get diagnostic information by starting Ryde in a terminal window:
If it crashes, the report will be displayed as the last thing on the terminal. I would suspect a faulty USB or HDMI lead, or a power supply problem. Hope that you can find the cause.
cd /home/pi/ryde
python3 -m rydeplayer /home/pi/ryde/config.yaml73
