DVB-T on a Jetson NANO
Post by G4GUO » Sun Jan 31, 2021 11:49 am
I thought I would relate my experiments using a Jetson NANO.
I am using the same software stack for transmit as the Portsdown uses.
I started by using the NGINX rtmp server but it consumes a huge amount of processing on the NANO.
So I have now swopped to using a a UDP (H.264) transport stream generated by OBS on my main PC.
On the NANO I use a version of FFmpeg that has support for hardware video encoding/decoding.
https://github.com/jocover/jetson-ffmpeg
This transcodes from h.264 to h.265 generates a transport stream which is then sends to the DVB-T stack.
Then using a LimeSDR I can get it to transmit up to a 6 MHz DVB-T signal. I would like to tweak the code to achieve
a full 8 MHz signal (just because I can).
I have not tried it yet but it should be possible to simply plug a webcam into the NANO and use that as a simple
video source for mobile operation.
I have used one of the LDMOS 60W brick amplifiers from G.H Engineering but only at about 5 watts output.
I am currently thinking about what would make the best mobile antenna setup. 1 antenna or 2 with power split
between them to give some diversity.
