display size
Pa3fbx
display size
Post by Pa3fbx » Sat Dec 26, 2020 8:19 pm
Hi there,
I have running the ryde software for some weeks now.
I have a smal hdmi touchscreen connected to the Pi4.
I have 2 smal problems witch keeps bothering me.
1. first problem is the startup.
it never works in 1 go. After applying power to both MT express, screen and Pi4 it boots nice and gives me nice sound but no picture...
i allways need to restart the app via the remote.
after restarting the software runs flawless for hours...
2. my screen is filled with the red screen of not locked.
Its a 16:9 screen and all seems wel but all pictures are squeesed with a black band both top end bottem.
No matter what size is been transimitted.
even the mute simbol is in the black top right.
So how should i get the complete screen filled...
These minor issues are just my loss but a solution would be appreciated...
73es and merry Christmas
Benno , PA3FBX
dl9sec
Re: display size
Post by dl9sec » Sun Dec 27, 2020 8:16 am
Morning Benno,
you could try to force HDMI mode in your config.txt at your RPi:
hdmi_force_hotplug=1
hdmi_group=1
hdmi_mode=16
hdmi_drive=2
(see https://www.raspberrypi.org/documentati ... t/video.md for details)
Maybe the overscan parameters are active, so comment them out.
Let me know, it that works for you...
73, Thorsten
BTW: Great xmas lightshow at your garage :D
Re: display size
Post by G8GKQ » Sun Dec 27, 2020 12:52 pm
Hi Benno
The "No video at start" is a VLC problem that I have seen before on the Portsdown. I had not seen it on the Ryde before. I'll have a think about it.
Please could you give us as much information about your display as possible? Including running
tvservice -s
from the command line to see what the system thinks about it.
Pa3fbx
Re: display size
Post by Pa3fbx » Sun Dec 27, 2020 1:41 pm
Thanks all for the support...
Dave, i typed the command in putty
pi@Raspberry:~ $ tvservice -s
state 0xa [HDMI CUSTOM RGB lim 4:3], 720x576 @ 50.00Hz, progressive
I will try Thorstens advice but lack some info where to find the config.txt...
Need some more searching...
I will also make a smal video on startup if i ever get my bench cleaned up...
Thanks sofar.
73es Benno
Re: display size
Post by G8GKQ » Sun Dec 27, 2020 1:58 pm
Hi Benno
From Putty, you can edit config.txt with the command:
sudo nano /boot/config.txt
Use ctrl-x and then y and enter to exit and save.
Not sure that Thorsten's settings will work for you. You could try
hdmi_group=1
hdmi_mode=16
hdmi_drive=2
But I'm afraid trial and error,(and lots of reboots) is required
Pa3fbx
Re: display size
Post by Pa3fbx » Sun Dec 27, 2020 8:56 pm
Thanks dave...
Found my best results...
hdmi_group=2
hdmi_mode=85
hdmi_drive=2
This tells my pi that i am using a monitor (group 2) and for this group there is a seperate mode set...
82 1920x1080 60Hz 16:9 1080p
83 1600x900 60Hz 16:9 reduced blanking
84 2048x1152 60Hz 16:9 reduced blanking
85 1280x720 60Hz 16:9 720p
And just to be sure i needed the drive on 2...
Now all stations are full screen and 16:9..
OSD still fine...
I'll try next few days the startup as it looks solved as well but that may just luck...
Best regards
73es Benno
dl9sec
Re: display size
Post by dl9sec » Mon Dec 28, 2020 12:28 pm
Hi Benno,
ah, ok no FHD, but HD.
I think group 2 mode 85 is the same as group 1 mode 4.
Nevertheless, great that you got fullscreen now :)
73, Thorsten
Pa3fbx
Re: display size
Post by Pa3fbx » Mon Dec 28, 2020 3:42 pm
Yes Thorsten. I have Tried fhd (82) but my Monitor was switching on and off a few Times before i got A Steady Image.. and there is no visable difference on A 7 inch display between HD and fhd. ..
IT works for me... And i AM more on qso in low res. than hres movies i netter download myself ....
Benno, PA3FBX..
