Config.yaml addings
Pa3fbx
Config.yaml addings
Post by Pa3fbx » Wed Dec 09, 2020 6:22 pm
Hi all,
Just to introduce me: i am Benno PA3FBX.
I was checking out this great project.
I would like to add or change some of the presets witch can be found in de config.yaml
Specially the frequency and Ks settings.
But Every time i'll add someting the dam thing will not load.
Tryied many times now so what am i doing wrong..
Know how to sudo nano the file and saving afterwards.
But as soon as i add a frequency or a KS in the scan preset the longmynd is crashing.
Best regards and keep on the great work.
Benno
Re: Config.yaml addings
Post by G8GKQ » Wed Dec 09, 2020 10:44 pm
Hi Benno
Some hints:
- There is a limit of 4 freqencies and 4 SRs for each preset
- Make sure you use spaces and not tabs
- Try running ryde from the command line, so that you can see the error report:
cd /home/pi/ryde
python3 -m rydeplayer /home/pi/ryde/config.yaml
Post by g4eml » Thu Dec 10, 2020 12:23 am
Indentation at the start of each line is also critical, an extra space or a missing space will stop it working.
Pa3fbx
Post by Pa3fbx » Thu Dec 10, 2020 4:42 am
Thanks .
will try...
