Ryde and DVB-T/T2/S/S2
Patrice
Post by Patrice » Wed Nov 25, 2020 10:37 am
The receiver Ryde is an excellent idee to use on repeter and at home.
Serit made a combo nim FTM4762H/FTM4762V compatible DVB-S/S2 and T/T2, is it possible in the futur to implement the Ryde (V3) with DVB-T/T2?
The DVB-T/T2 is most robust when is use in town.
could you ask to your developper to check if is possible or not.
Best regards
Patrice F1NSU
Re: Ryde and DVB-T/T2/S/S2
Post by G8GKQ » Wed Nov 25, 2020 11:42 am
Hi Patrice
Thanks for pointing this out.
We actually already have a team working on this, and have an early prototype DVB-T receiver working using this tuner. However, there is a lot of work to do before it is mature enough to be released as a Ryde-style receiver for general use.
One note of caution - the DVB-S/S2 receive frequency range of this tuner may be limited to 950 - 2150 MHz, so we are not planning on a dual capable (DVB-S and DVB-T) receiver yet.
Patrice
Post by Patrice » Thu Nov 26, 2020 12:49 pm
Thank you Dave, because the Paris's repeater will use an output DVB-T lite (1.7MHz BW) like R&D BBC
best regards
Patrice F1NSU
