Portsdown 4 /Langstone build bandswitching
M5TXJ
Post by M5TXJ » Mon Nov 16, 2020 1:45 pm
Hi all,
Combined build is progressing slowly but I've now got a question. This is probably very obvious but I'm possibly confusing myself. On the GPIO there is the Portsdown D0, D1 and D2, there is also the Langstone D0-D7 (some shared). I'm hoping to use a BATC 8 way switch, do I use the Portsdown data bit pins and simply map the Langstone "band bits" to give a comparable output? Hopefully someone has done this already and can point me in the right direction.
73 Dave.
Re: Portsdown 4 /Langstone build bandswitching
Post by G8GKQ » Mon Nov 16, 2020 2:07 pm
Hi Dave
Yes, just use the Portsdown D0, D1 and D2 Band bits, and set the Langstone to give the right patterns on those bits. The extra Langstone bits are there to allow the use of non-BATC switching boards.
M5TXJ
Post by M5TXJ » Mon Nov 16, 2020 2:24 pm
Thanks Dave
That makes sense.
73 T'other Dave
