QO-100 beacon MER
QO-100 beacon MER
Post by g8gtz » Thu Oct 29, 2020 8:41 pm
As mentioned on the BATC Thursday night net, it would be good to know what MER people are getting the beacon at so others know how well (or not) their system is performing:
G8GTZ - 1.2mt dish - MER 9.6 and D4.8
Re: QO-100 beacon MER
Post by M0DTS » Thu Oct 29, 2020 10:37 pm
8.9dB using 1m dish and no other signals on the sat.
Octagon green 4-port LNB.
Cherry tree is causing some degradation though....
Post by g0mjw » Thu Oct 29, 2020 10:44 pm
This evening on the net it was around 10.5 measured by Winterhill. It's peaking 11.5 now, range 11.3-11.5 on the Ryde. That's probably partly the difference in the tuners and partly there are no other signals at the moment.
The lift in the noise floor was about 5 dB in August 2019., it's less now the trees have grown again.
Post by G8GKQ » Thu Oct 29, 2020 11:29 pm
1.2m offset dish, POTY, MER 9.5dB on an Empty Transponder.
arthur21
Post by arthur21 » Fri Oct 30, 2020 9:06 am
Empty band and a 1m offset dish MER 9.5 ( rx only dish ) Octagon lnb
73 G4CPE
Don_EI8DJ
Post by Don_EI8DJ » Fri Oct 30, 2020 12:13 pm
Mer 9.1 on 1.1m offset dish with octagon lnb
regards to all
G4KLB
Post by G4KLB » Fri Oct 30, 2020 6:19 pm
1.2M offset dish, Bullseye LNB.
Beacon is 10.6dB MER D6
g4hiz
Post by g4hiz » Sat Oct 31, 2020 6:58 am
Beacon reception at JO01fg, 06.37, 31/10. Wx cloudy/overcast but dry, very breezy.
Antenna 1.2m prime focus. LNA Octagon, H-pol (18V) with modified LO @ 9.389GHz, using POTY. Receiver Minitiouner (Serit tuner).
Transponder traffic: beacon plus one low NB carrier
Using Minitioune on laptop, s/w V0.9_9.1h MER 10.7 to 10.9dB, D6
Using Longmynd on Portsdown, s/w 202010180 MER 10.8 to 11.0dB
Jen
G8XZD-TV
Post by G8XZD-TV » Sat Oct 31, 2020 8:32 pm
sky zone 2 dish empty transponder 6.2mer
Post by g8gtz » Tue Nov 10, 2020 6:11 pm
Thanks for the responses.
I've been monitoring the MER using the Portsdown large screen readout and seen a variation of 3dB between 10db on an empty transponder and 7dB with the useage below!
A single large signal can drop the MER by 1 dB - something to be aware of when tweaking your dish!
73 Noel - G8GTZ
