Update for Portsdown 4 (Raspberry Pi 4)
Post by G8GKQ » Sun Oct 04, 2020 9:27 pm
I have just published a software update for the Portsdown 4. It includes 2 changes to the GPIO pin allocations to move services off of 2 pins that are reserved on the Raspberry Pi 4.
  • The first is that the band LSB connection moves from pin 28 to pin 32
  • The second is that the pin allocated for ADF4351 LE (unused on the Portsdown 4 until now) moves from pin 27 to pin 33.
Colin has already published details of coordinated changes for the Langstone band switching.
The full list of changes and new features is:
  • Modify Band LSB and ADF4351 LE GPIOs
  • Add Initial ADF4351 Sig Gen Capability
  • Blink display on successful snap
  • Reduce dhcp timout for new builds
  • Use Raspios Buster Lite 2020-08-20 for new builds
So, with the addition of an ADF4351 (as used with the Portsdown Filter-Modulator board) your Portsdown can serve as a Signal Generator from 35 MHz to 4.4 GHz; connections (pins 29, 31 and 33) are published here https://wiki.batc.org.uk/Portsdown_4_GPIO_Connections. Future updates will extend the library of output devices and hence the frequency range. You can select the signal generator from Menu 2.
Other changes blink the display to indicate successful screen capture and, for new builds only, reduce the boot time with no network connection and use the latest Raspios software.
g7ntg
Re: Update for Portsdown 4 (Raspberry Pi 4)
Post by g7ntg » Sat Oct 10, 2020 12:36 pm
Hi Dave
My portsdown 4 crashed and would not start again so I formatted the card and started again and now the pi screen asks for me to login and wont go any further. I tried making a new card again and also with a fresh sd card but in every case it stalls at " raspberrypi login:"
I take it this is a glitch in the software?
g7ntg
Post by g7ntg » Sun Oct 11, 2020 12:00 pm
I originally crashed portsdown 4 but when I rebuilt the card I built it as Portsdown 2020 because I logged onto the wrong Wiki page!
That's why it wouldn't work! I should have been paying attention so make sure you are on the right page if you are in a similar position!
Sorry to waste yopur valuable time Dave!
