Delay when switching from Langstone to Portsdown on Portsdown 4
G4FVP
Post by G4FVP » Thu Aug 13, 2020 11:15 pm
I have just installed Portsdown 4 and downloaded Langstone off Menu 2. Works well - but I note when switching from Portsdown to Langstone it switches across in a few seconds but when switching from Langstone to Portsdown it takes several minutes. Anyone else observed this? and if so any thoughts on a fix. 73 Clive G4FVP
Re: Delay when switching from Langstone to Portsdown on Portsdown 4
Post by G8GKQ » Fri Aug 14, 2020 9:16 am
Hi Clive
Is your Pluto still on its default IP address (192.168.2.1) or have you changed it? If you have changed it, you will need to tell the Portsdown the Pluto's IP address (Menu 3, Langstone Config, Pluto IP).
