Portsdown 4 - First build now available
Discussion about this major DATV Project. See also https://wiki.batc.org.uk/The_Portsdown_Transmitter
G1LPS Terry
Re: Portsdown 4 - First build now available
Post by G1LPS Terry » Fri Jul 31, 2020 6:13 pm
f1faq
Post by f1faq » Sat Aug 01, 2020 8:42 am
Euh Dave,
Applied your mod via SSH but still "Unable to contact Github" "Internet to Google seems Ok"
but also "Current Software Version :" nothing displayed !
Something you missed ?
73 - Christian
F1FAQ
73's - Christian
F1FAQ
f1faq
Post by f1faq » Sat Aug 01, 2020 9:29 am
After reboot, now "Current Software Version" changes each time : M3 / M3 band / 10 / ....
For your info : To build Portsdown I have dowloaded the soft via your repo (-d option)
If this can help
73's - Christian
F1FAQ
Post by G8GKQ » Sat Aug 01, 2020 3:37 pm
Hi Christian
Now corrected. My apologies - I still need to set up a separate system for testing, so I had cut some corners and missed some errors. You will need to run the script as before:
cd /home/pi
wget https://raw.githubusercontent.com/BritishAmateurTelevisionClub/portsdown4/master/update.sh  -O /home/pi/update.sh
chmod +x /home/pi/update.sh
./update.sh
Please use the main BATC build, as the dev build (davecrump) is often untested with errors.
f1faq
Post by f1faq » Sat Aug 01, 2020 3:50 pm
Working now Dave
Many thanks
73's - Christian
F1FAQ
F1CJN_alain
Post by F1CJN_alain » Sun Aug 02, 2020 8:14 am
Hi Dave and all
I am using the 202008013. Good job !
The screen is upside down, except the video on the screen when I use the picam for transmitting
The reboot does not work (black screen). It works when I disconnect and reconnect the power supply.
73s
Alain F1CJN
Post by G8GKQ » Sun Aug 02, 2020 9:24 am
Alain
You can invert the screen from: Menu 3, System Setup, Invert 7 inch and then reboot.
Reboot sometimes takes 90 seconds - please could you wait that long and tell me if it does eventually?
F1CJN_alain
Post by F1CJN_alain » Sun Aug 02, 2020 9:42 am
Thanks for the screen reversal.
After 6 minutes still no reboot for me .
73's
Alain F1CJN
Post by G8GKQ » Sun Aug 02, 2020 10:02 am
Alain
Pleased that the screen reversal was OK.
What other things do you have connected to your Raspberry Pi?
7 inch screen, Pi camera and .......
F1CJN_alain
Post by F1CJN_alain » Sun Aug 02, 2020 11:29 am
Just the lime and Ethernet, 7 " screen and RPIcam are connected to the RPI4
73's
Alain F1CJN
