Longmynd not loaded - Solved
G1LWX
Post by G1LWX » Fri Jul 17, 2020 2:14 pm
HI
Started to build the Ryde project this morning.
Raspberry pi 4 4Gb.
Minitiouner.
Hdmi to vga convertor.
Sd card built up as per wiki.
After loading the software and rebooting "Longmynd not loaded" flashes up for one second
then goes back to prompt.
I have rebuilt the sd card twice but still having problems
Mike G1LWX
MW0RUD
Re: Longmynd not loaded
Post by MW0RUD » Fri Jul 17, 2020 3:17 pm
Hi Mike,
Can you ssh in and run this for me and post the output?
cd /home/pi/ryde
python3 -m rydeplayer /home/pi/ryde/config.yaml
Tim
G1LWX
Post by G1LWX » Fri Jul 17, 2020 5:09 pm
Hi Tim here you go
login as: pi
pi@192.168.8.188's password:
Linux raspberrypi 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jul 17 17:04:25 2020
pi@raspberrypi:~ $ cd /home/pi/ryde
pi@raspberrypi:~/ryde $ python3 -m rydeplayer /home/pi/ryde/config.yaml
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
Namespace(**{'Config File': '/home/pi/ryde/config.yaml'})
/home/pi/ryde
Handset has no button definitions
Frequency: 741500
Symbol Rate: 1500
Polarity: PolarityEnum.NONE
Port: inPortEnum.TOP
[None]
Traceback (most recent call last):
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/home/pi/ryde/rydeplayer/__main__.py", line 20, in <module>
player.run()
File "/home/pi/ryde/rydeplayer/player.py", line 327, in run
newplayer = player('config.yaml')
File "/home/pi/ryde/rydeplayer/player.py", line 237, in __init__
self.vlcStartup()
File "/home/pi/ryde/rydeplayer/player.py", line 319, in vlcStartup
self.vlcPlayer = self.vlcInstance.media_player_new()
AttributeError: 'NoneType' object has no attribute 'media_player_new'
MW0RUD
Post by MW0RUD » Fri Jul 17, 2020 5:22 pm
Hi Mike,
Looks like something might have gone wrong during the install as it doesn't looks like VLC is installed. Can you try doing
sudo apt-get install vlc
Tim
G1LWX
Post by G1LWX » Fri Jul 17, 2020 5:51 pm
OK
Now instead of flashing on for a second I am now getting the red screen with "Longmynd not loaded" all the time.
I have just noticed that it is showing an under voltage so that may explain things in the download.
Post by G8GKQ » Fri Jul 17, 2020 8:16 pm
I would suggest sorting out the power supply and then rebuilding the SD Card from scratch. Generally easier than troubleshooting a partial install.
G1LWX
Post by G1LWX » Sat Jul 18, 2020 8:26 am
Ok Dave/Tim
Sorting out a more robust psu today then will try another rebuild.
Never had a problem before building cards, psu must have been borderline.
Will report back.
Mike G1LWX
G1LWX
Post by G1LWX » Tue Jul 21, 2020 9:50 pm
Update
New 10A psu and rebuilt sd card all now ok.
dl9sec
Re: Longmynd not loaded - not solved for me
Post by dl9sec » Fri Dec 18, 2020 4:05 pm
today i did a first time and fresh install of Ryde on a brand new 8GB RPi4.
The installation works well so far, nor errors.
I installed my custom TT-connect remote control which seems to work basically.
The very first time I started Ryde, I immediately got the beacon demodulated.
Since then I never got a demodulation anymore, but "Longmynd not loaded" :(
I tried several things (6A PSU, checked my MinitiounerPro V2 with the Minitiouner software which works well, re-powered the Minitiouner), but I couldn't get it work again.
This is the output of "python3 -m rydeplayer /home/pi/ryde/config.yaml":
[pi@raspberrypi ryde]# python3 -m rydeplayer /home/pi/ryde/config.yaml
pygame 1.9.4.post1
['dejavuserif', 'dejavusansmono', 'freesans', 'dejavusans', 'freeserif', 'freemono']
/home/pi/RydeHandsets/definitions
Request Frequency: 10491500
        IF offset: -9750000
      Symbol Rate: 1500
--width 1920 --height 1080 --codec ffmpeg
[00ce9640] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00cee3a0] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
Unknown IR codes:
['VOL+', 'VOL-', 'CHAN+', 'CHAN-']
start
['/home/pi/longmynd/longmynd', '-t', '/home/pi/lmmedia', '-s', '/home/pi/lmstatus', '-r', '5000', '741500', '1500']
Ready
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
State.Stopped
Flow: main
      Status: Main Frequency=741500 KHz
              Main Symbol Rate=1500 KSymbols/s
              Using First Minitiouner detected on USB
              Main TS output to FIFO=/home/pi/lmmedia
              Main Status output to FIFO=/home/pi/lmstatus
              Main refers to TOP F-Type
              TS Timeout Period =5000 milliseconds
Flow: Fifo Init
      Status: opened fifo ok
Flow: FTDI init
Flow: FTDI USB init
Flow: FTDI set mpsse mode
Flow: FTDI USB init
Flow: FTDI setup io
      Status: MPSSE Synched AA FA
Flow: FTDI nim reset
Flow: FTDI GPIO Write: pin 0 -> value 0
Flow: FTDI GPIO Write: pin 0 -> value 1
Flow: Fifo Init
Flow: NIM init
Flow: STV0910 init
Flow: stv0910 init regs
      Status: STV0910 MID = 0x51, DID = 0x20
Flow: STV0910 set MCLK
Flow: Setup equlaizers 1
Flow: Setup carrier loop 1
Flow: Setup timing loop 1
Flow: Tuner init
Flow: Tuner cal lowpass
Flow: Tuner set freq
      Status: tuner:0, f_vco=0x2d41f0, icp=0x2, f=0x2eeee, n=0xc5,
              rdiv=0x1, p=0x1, freq=741500, cfhf=2331
Flow: LNA init 1
      Status: found new NIM with LNAs
ERROR: failed to recognise LNA ID 1 0
ERROR: LNA init 1
ERROR: failed to init a device - is the NIM powered on?
Flow: Main loop aborted, waiting for threads.
Flow: All threads accounted for. Exiting cleanly.
State.Stopped
There seems to be several problems:
- This pulseaudio error message
- Unknown IR code for VOL and CHAN (used the yaml-template from https://wiki.batc.org.uk/Ryde_remote_controls)
- and something with the tuner (which seems to be detected well, and yes the NIM FTS-4334L is powered on and externally powered)
Any ideas?
Thanks in advance.
73, Thorsten
Post by G8GKQ » Fri Dec 18, 2020 8:08 pm
Hi Thorsten
The problem is with the tuner. The PulseAudio and IR Code messages are normal. The actual error is here:
Flow: LNA init 1
ERROR: LNA init 1
Unfortunately no-one on the development team has a MinitiounerPro V2 to test with as the Ryde is designed for the BATC MiniTiouner Version 2.
Asking the community: has anyone else seen this problem with a MinitiounerPro V2?
