Ptt portsdown buster failure I need help:
Raspberry pi 3+ together with Lime sdr mini with Buster porstdown and LimeDVB firmware.
The PTT signal is taken from the Gpio 21 pin 40.
In display mode everything works correctly the ptt signal is collected on pin 40.
In ssh and iptsin mode there is no ptt signal on pin 40.
Some kind colleague could indicate, and where I am failing.
Thank you 73
JOAN
Thank you 73
JOAN
Re: Ptt portsdown buster failure I need help:
Hi Joan
I do not think that you are failing. It is that the later versions of Portsdown have been designed to work with the Touchscreen and not the SSH Console menu. So, the PTT is probably not set in the SSH Menu when using IPTS in.
I will add it to the list of things to fix in the next release.
Thank you very much for the quick answer.
I am very grateful for the effort you have been making with portsdown and maintaining this forum.
The function would be very useful.
Is there a configuration or system that allows portsdown to be broadcast in ssh mode?
73 joan
73 joan
Doing a reflection in console mode, ssh, when I give the action to transmit the pi it does, the only thing that the gpio 21 pin 40 is not activated, but the file transmits with what it could take the ptt change of the gpio of the lime .
Someone could confirm it.
Thank you and sorry for the inconvenience.
Joan 73
EC3DBA
Joan 73
EC3DBA
Hi Joan
This problem should be cured in the latest Portsdown Buster release (202006070), so simply run an update and it should work after that.
Thank you , Dave
73 Joan
73 Joan
