LimeSDR mini Test Report failures
- G1LPS Terry
All seemed to function but running the report showed the attached errors.
Thanks for any help
Terry
- fails on test report
- 2.jpg (104.16 KiB) Viewed 12599 times
- 1
- 1.jpg (111.67 KiB) Viewed 12599 times
Re: LimeSDR mini Test Report failures
Hi Terry
The general opinion seems to be that this self-test function on the LimeSDR Mini is too sensitive to component tolerances and that a failed test does not necessarily mean that the LimeSDR will not function as desired.
If it is transmitting OK, I suggest that you do not need to take any further action.
- G1LPS Terry
Thanks Dave
That is reassuring.
seems to work OK with Portsdown and Express so I will leave alone.
BR
Terry
That is reassuring.
BR
Terry
I have seen the tests fail in a similar way when the Lime was connected to an external amplifier. Disconnecting it resulted in the test passing.
