LimeSDR mini low output on 2.4 with LimeDVB firmware
G8XZD-TV
Post by G8XZD-TV » Mon Apr 27, 2020 9:08 pm
At output 99 I get circa +4dBm on 437 and 1249Mhz; 90 -6dBm and at 80-12dBm
But at 2.4 I seem to get < -10dBm @ 99
Is this usual? What do other people get - trying to drive a Stealth 2025-44 (which needs -10dBm)and getting no where near what's expected.
All the leads are good quality and tight.
Any suggestions/comments? Has anyone plotted the output/frequency with the LimeDVB firmware
73.
Ian.
Re: LimeSDR mini low output on 2.4 with LimeDVB firmware
Post by G8GKQ » Tue Apr 28, 2020 9:14 am
Hi Ian
Lime Gain is set and saved separately for each band.
Please confirm that you have Lime Gain set to 99 for 2400 MHz. You should then get -2 dBm output at 2400 MHz (DVB-S2, 333 kS, FEC 9/10 displaying RPi Desktop). I measured -9.8 dBm output (as you reported) with the default Lime Gain for that band of 90.
Post by g8gtz » Tue Apr 28, 2020 9:51 am
Return to “LimeSDR Mini”
