LongMynd + Portsdown
i2NDT
Re: LongMynd + Portsdown
Post by i2NDT » Thu May 21, 2020 12:01 pm
does LongMynd + Portsdown work with Minitouner Express?
Claudio
i2NDT Claudio
Dalmine, Italia
G4GUO
Post by G4GUO » Thu May 21, 2020 1:06 pm
I compiled the Longmynd software from Github on a desktop Linux machine and was able to receive QO-100 signals on a Minitiouner-Express wih it.
- Charles
i2NDT
Post by i2NDT » Thu May 21, 2020 1:16 pm
thanks Charles,
I asked because I cannot see the demodulated images...
I get the text with the infos of the beacon but not the images.
maybe I am doing something wrong!
I will try again with other signals in case is the beacon which is bad.
Claudio
i2NDT Claudio
Dalmine, Italia
G4GUO
Post by G4GUO » Thu May 21, 2020 1:32 pm
I was using the Longmynd software on it's own and piped the output to VLC without any of the other stuff.
- Charles
Post by G8GKQ » Thu May 21, 2020 1:50 pm
Claudio
You cannot receive the beacon using Portsdown Buster 2020. You might get the audio with the VLC player, but no video.
Portsdown A27 on Langstone includes MPlayer, and this will give you about 10 seconds of beacon video.
If you are seeing the text about the beacon, then the tuner is working. Simply select another signal on QO-100 and use VLC player - all should become clear!
i2NDT
Post by i2NDT » Thu May 21, 2020 3:42 pm
well...I always need a few kicks in the azz to start running!
now it's OK: I used the UDP feature to multicast the signal on my network and demodulate it with VLC and so I could see the beacon very well!
Claudio
i2NDT Claudio
Dalmine, Italia
