Pluto not transmitting when OBS stream indicator is green.
darrenrainer
Post by darrenrainer » Wed Jan 29, 2020 11:03 am
Hi all,
I have updated my Pluto to the Custom firmware. The Pluto transmits ok using DATVExpress but doesn't go into a transmit state when I stream from OBS to the Pluto. The OBS stream indicator goes green indicating it is successfully sending to the Pluto and I am using the settings from the examples on the Wiki. I am making sure I am sending video at the correct rate so it stays green on OBS. I have tried with and without power supply on the Pluto. Any idea please ?
73s
Darren G4VTQ
g8lce
Re: Pluto not transmitting when OBS stream indicator is green.
Post by g8lce » Sat Feb 01, 2020 10:33 am
Hi Darren,
You could try vMix and see if that works. I think the stream settings are similar. vMix stream goes red when working.
Martin G8LCE
Post by g0mjw » Sat Feb 01, 2020 7:42 pm
Network problem possibly ruled out be green indicators. You have not sent the right commands, or you have not got the settings right for the data. Oh - and the pluto does not go into transmit, it's duplex. It might be sending at a level you can't detect. The best was to diagnose this is to ssh into the pluto and look at what processes are running.
darrenrainer
Post by darrenrainer » Sat Feb 01, 2020 9:28 pm
Thank you both for the replies. I'm not quite sure what has changed but it is now working. I have even got it working on the network connection using a otg adaptor. Next thing is I need to short out the two grounds on the pluto pcb as the pluto looses the network connection as soon as I plug in my 20w sglabs amplifier. Hopefully will have this on the air by the end of the weekend
73s
Darren G4VTQ
