Second-Stream USB board: testing and using
Terry-G0EZY
My minitiouner main board is built and passes the two test programs.
TestMyMiniTiouner_V2_0a
CheckMiniTiouneDriverAndFilters_V0_5a (the two test pictures run OK)
MiniTioune_V0_8s boots up OK and appears to work with no error nessages - but I've done no on-air checks yet.
I have built the USB second stream board but not sure how to test it. I have tested the 2nd FT module in the main board slot and it works OK, so chip is programmed correctly. The main board FT module requires a small mod (fit 10k resister). Is this required on the 2nd stream board (the photos do not show it fitted.
When I plug in the 2nd stream board and connect both USB to the PC and run the test program error message says "no NIM"
What have I done wrong?
73 Terry
73 Terry
Re: Second-Stream USB board: testing and using
As far as I know it won't work yet, we're waiting on a software update before it will work. I did see a tweet from F5OEO Evariste about the new Minitoune so hopefully that will include the update when released ?
John
John
Yes I have the second stream board fitted in anticipation of the new software.
So no worries it won't be recognised with the version you're using.
Steve
Steve
This is why the board is not yet in the shop. We are waiting for the updated software to support it.Terry-G0EZY wrote: ↑Fri Jan 17, 2020 11:01 amMy minitiouner main board is built and passes the two test programs.
73 Terry
Terry-G0EZY
Many thanks for the replies/assistance. I bought the additional board and FTDI module at the BATC rally at Finningley.
For some reason I was sure I'd seen a post that the Dual-Stream software was available. Obviously must have been in my imagination!
Any ideas yet whether the resistor modification will be necessary on the additional board?
73 Terry
73 Terry
OK - That's odd as they were not going to be available for sale (as far as I know) to avoid situations like this. We don't know about the resistor yet but I think not as it is used to determine which type of main board is used. F6DZP has a new version available according to a post today but I don't know if it will support a second TS. It does include the spectrum analyser apparently.
