Portsdown and Jetson SSH problem
G4WIM
Post by G4WIM » Mon Nov 25, 2019 12:31 pm
I've got something odd going on (again).
I've just built a new Jetson image and it works fine by ssh into it to set the various parameters etc so I know I have the right username and password etc. PIcam works, IP source works.
But when I try to control it from Portsdown with the same parameters nothing happens - can't even shut it down.
Using wireshark I see SSH session being set up but not sure if it's successful, I also notice that F5OEO made a change to nanoencode.sh a couple of months back.
Portsdown works ok with an earlier Jetson image so suspect something has changed.
Any ideas on how to debug / fix ?
73 Tim
Re: Portsdown and Jetson SSH problem
Post by g0mjw » Mon Nov 25, 2019 12:38 pm
You may have changed the trust certificate. Try SSH from the PI to the Jetson. Then accept and save the new identifier. It will then work hopefully.
G4WIM
Post by G4WIM » Mon Nov 25, 2019 7:02 pm
Hi Mike,
good idea - hadn't thought of that !
Will report back later.
73 Tim
G4WIM
Post by G4WIM » Mon Nov 25, 2019 7:56 pm
Hi Mike,
that did the trick - just had to remove the old key from trusted hosts on the rpi and all is good again !
This may help others when they're trying out different combinations and run into the same problem of not having ssh working properly.
73 Tim
