1.3Ghz Circulator / Isolator
If you are looking for something, ask here
G8DKC
Post by G8DKC » Thu Sep 12, 2019 2:37 pm
Looking fo a 1.3Ghz Circulator, I have one that goes to about a watt or so...
Unlikley able to change 50 ohm load, and if I did the device may not handle up to 15w let alone 25W.
I may be able to turn power down /off using SWR Mon output on the P.A
But if you have one between 15w and 25w it would be very usefull, rather than trusting an electronic method...
Looking on EBay .uk .com daily.
Please P.M or direct... peter@inagnu5.plus.com.
Peter
G8DKC
Re: 1.3Ghz Circulator / Isolator Found
Post by G8DKC » Thu Sep 12, 2019 4:32 pm
Thank you for reading.
After weeks of searching found one on Ebay.com this very afternoon...
100w 3 port SMA coax sockets, so fit your own 50 ohm load, last one too.
So quite relieved :)
Peter
Return to “Wanted”
