CODEC Advice Needed
Re: CODEC Advice Needed
Just bought a NUC and I'll be installing Windows 10. It will be interesting to see if I get the same issue.
Steve
Steve
Find me on D Star through GB7BP
Hi G4NRT,
Have you had success while buying and installing the HEVC extension from MS?
It seems that I lost the extentions too while installing the latest Win10 pro update....
Rainer
Rainer
Hi Rainer,
Well, I paid my 79p and downloaded and now installed the Microsoft HVEC CODEC.
No change. I’m still not able to render video inside Minitioune.
I’m hoping against hope that someone can find a way to fix this. My entire DATV project is on hold until they do!
73, David
73, David
Regarding Minitioune to VLC, this works for me, with both software on the same computer.
In the minitiouneConfig.ini
Add “;” to this line, e.g. ;TS_AddrUDP=230.0.0.10
Remove the “;” on this line TS_AddrUDP=127.0.0.1
Change port number to
TS_Port=1234
In VLC network protocol URL use, udp://@:1234
Regarding the H265/HVEC CODEC, As far as I can tell Minitioune uses a built in “VH265” codec and cannot use the Microsoft one.
Hope this helps
John
TS_Port=1234
Hope this helps
John
Hi John,
I have no problem getting Minitioune to VLC to work on my old Windows 10 PC. It will not, however, work on the new one - even with the same settings per your post. The VLC windows remains resolutely blank!
When I run Minitioune on my old PC it all works fine and if I use the "Test My Minitioune" application I get all green lights but the box where I should see either the QSL card or the rotating BATC logo remain black! It is definitely to do with my new implementation of Windows 10 on my new Intel NUC.
You'll need to plough through all four pages to see the entire saga ...
David
David
Hi David
Looking on Jean-Pierre F6DZP website http://www.vivadatv.org , he suggests to someone with similar problems that the problem is with “Windows that cannot render the video using Directshow.”
The guy never got back to him so I'm assuming he fixed it.
I guess you will have tried the following, but just in case.
Try installing the latest LAV filters as Administrator
https://github.com/Nevcairiel/LAVFilters/releases
It seems that Directshow is not installed automatically with Windows 10 any-more but the drivers appear to be in the following Codec installers. ffdshow and the K-Lite Codec Pack Full
Apart from that I'm out of ideas, the only other thing I can suggest is running the affected programs as Administrator, in case its a file access problem.
Hope you get it fixed
73 John M0IVJ
73 John M0IVJ
Hello David,
New NUC installed Windows 10 Pro, then from the Intel NUC website downloaded and installed all the Intel specific drivers.
Next installed latest LAV filters and ran the usrx file. Minitioune software is all working as it should.
No additional decoders installed and no complications.
Regards
Steve M0SKM
Regards
Steve M0SKM
Hi John,
Yep! Latest set of LAV filters v74.1 (I’m away from the computer so that’s from memory). Everything has been run as Admin and without.
I put a detailed description of my problem on Pierre’s forum. Dozens of views but not a single answer!
I’m also out of ideas so shelving the entire project for the time being pending someone else having the issue and solving it!
Thanks in any case for your advice!!
David G4NRT
David G4NRT
See above; we posted at the same time.
Steve
Steve
