Serit dying
Serit dying
I built a V2 MiniTiouner a couple of days ago and noticed there was no +12V on the 'A' Ftype.
Not a problem - I used the 'B' one instead. This was fine for a couple of days till this morning when I switched on and noticed the PSU current dropping from 240mA down to about 120mA
I checked and found there was no 12V now on the 'B' f type. The thermal fuse (300mA) hadn't tripped.
I moved the LNB feed to my NB receiver setup and there were no issues and the LNB drawing was drawing about 100mA.
I've opened the serit and found what I presume to be the two tiny inductors that feed the +V to the Ftypes - on one end there was 12V and nothing on the other. There were splashes of solder/metal in there though
So in short does anyone know what the value of this inductor might be?
Richard
Richard
Re: Serit dying
Hi Richard,
I believe that quite a few have had this problem, me included. What I have done, others too I understand, is fit a through hole inductor and polyfuse inside the Serit NIM. I fitted a 10uH inductor and 300mA polyfuse in series between the centre pin of the F socket and theLNB voltage input pin of the NIM with the inductor as close as possible to the F socket. I don't know the original inductor specs but as 10uH has an impedance of around 50K ohms at the frequencies we're using I went with that.
There is this thread showing a fix, this OM has used a hairpin inductor rather than a through hole one as I did but you'll get the idea.
viewtopic.php?f=105&t=5942&hilit=lnb+voltage&start=10
73 Dave.
73 Dave.
Re: Serit dying
Me again, I should add that using a 10uH inductor means its impedance at 146.5MHz is approaching 10K so can be used to feed a 2m masthead preamp as well as an LNB.
73 Dave.
73 Dave.
Re: Serit dying
Thanks - that is brilliant. The parts only arrived for it on Wed morning and I built it in the evening - like any new toy I want it to be perfect and to have one socket DOA and the second dying after a days use was a bit upsetting.
time for a quick RS order then
Re: Serit dying
An alternative which is easier to replace in the confined space is a standard ferrite bead with a couple of turns of wire.
One end can go on the centre pin of the F socket
Adrian
Adrian
Re: Serit dying
This is the mod to my Serit, I have since changed the 1uH for a 10uH for better performance at 146.5MHz as in my earlier post.
73 Dave.
73 Dave.
- 5222019161032.jpg (135.67 KiB) Viewed 11494 times
Re: Serit dying
Thanks for that Dave, just did as you pictured there after losing voltage on that socket and it's working fine now.
Re: Serit dying
just asking if you can provide more info about the 10uH inductance.
I tried to find RFC (Choke) in Digikey but no workable results.
Then I tried only Inductance and found something like M10135-ND
My question now, to decide what to buy, is how have to be the Auto-resonance Frequency or any other HF critical parameters?
Thank you!
73 Luca
Thank you!
73 Luca
Re: Serit dying
Hi Luca,
the choke isn't critical, I just used one from a typical Chinese sellers 0307 size selection I bought from Ebay, something like this.
https://www.ebay.co.uk/itm/1-4W-Color-R ... 2052303138
73 Dave
73 Dave
Re: Serit dying
Hi Dave
Can we add the picture of your mod to this wiki page: https://wiki.batc.org.uk/Serit_LNB_DC_supply
