LimeNET Micro support
HB9DUG
Post by HB9DUG » Wed May 29, 2019 5:50 pm
I have been successful to install and run Portsdown 2019 using the standard installation process on a LimeNET Micro, but for the RPI 7" display and camera to work, we need to "attach" them to the Compute Module 3 (CM3) used by the LimeNET Micro with the following cmd :
sudo wget https://goo.gl/gaqNrO -O /boot/dt-blob.bin
and reboot.
It would be nice if this cmd could be added in the installation script file and even more in the update process which delete the dt-blob.bin file.
Of course I will be more then happy to help testing the updated scripts files.
73 qro de michel, hb9dug
Re: LimeNET Micro support
Post by G8GKQ » Fri May 31, 2019 9:11 pm
Hi Michel
This is not going to be the easiest to fix, as dt-blob.bin also needs to be customised for other aspects of the Portsdown (Ugly Mode).
I've added it to my list.
