c920 powerline frequency setting
gi7ugv
Post by gi7ugv » Tue May 14, 2019 1:11 pm
I just got around to looking at the flickering I was seeing on the c920 in Linux and it turned out to be an easy fix.
There is a power line frequency setting in the camera that defaults to 60Hz that with my lighting and walls ends up looking pretty bad. Figure changing this might be handy for other users and the Portsdown too, it doesn't survive a reboot so will need set on startup.
You can view the current setting selecting the correct video device:
v4l2-ctl -d /dev/video0 --all| grep freq
           power_line_frequency (menu)   : min=0 max=2 default=2 value=2
"power_line_frequency" set to 1 selects 50Hz, while set to 2 (default) it is 60Hz.
It is easy to change with:
v4l2-ctl -d /dev/video0 --set-ctrl power_line_frequency=1
The following video shows changing between the two on a Portsdown TX with the c920 in webcam mode starting off on the default 60Hz.
https://youtu.be/wvam7bu9Bz8
Re: c920 powerline frequency setting
Post by G8GKQ » Tue May 14, 2019 1:59 pm
Thanks John
I can put that in the next release, and only implement it for PAL users.
Really useful!
