No picture om Minitiouner
ZS1MM
Post by ZS1MM » Mon May 13, 2019 12:56 pm
My minitiouner passes all the tests perfectly. I transmit with my Portsdown transmitter and check the output with a STB. The picture is perfect. On the minitiouner everything locks as it should but the last led on the TS group stays red and there is no picture. Is this a hardware problem or is it a windows setup problem? This seems to be quite a common problem. I have already replaced the 74HC10 chip and checked all its inputs and output with a scope and the activity is there.
Can anyone please help.
Leon
ZS1MM
Re: No picture om Minitiouner
Post by G4GUO » Wed May 15, 2019 2:53 pm
While I can't talk about the BATC units I have seen this problem on a couple of Minitiouner-Express units returned to me under warranty.
Both BATC and Express units are very similar in design.
In one case it turned out to be a dry joint inside the Serit tuner itself and the other a short on the D clock line.
Check you have sensible data on all the transport stream pins including the sync and d clock ones coming out of the Serit
and that the impedance of the lines is in the order of 300 K or greater. The shorted tuner appeared as 3.4 ohms.
Post by g8gtz » Wed May 15, 2019 4:42 pm
Hi Leon,
As Charles says, this could be the Serit NIM although not sure why the last "led" stays red. I have had 2 failures in the 600 or 700 shipped from BATC.
Can you test it on a satellite signal to see what results you get on that - Lyngsat says there is a number of free to air signal which MT will decode - https://www.lyngsat.com/freetv/South-Africa.html. Or alternatively if you are set up to receive Oscar100, see if you can decode the beacon.
Post by G4GUO » Wed May 15, 2019 4:54 pm
The last led indicates 'bytes are received in the buffer' and I suspect it means bytes in the minitioune SW buffer. I suspect he is not seeing any SI tables either. We see that when the NIM thinks it has a valid signal but the data being passed between the NIM and USB is non existant, usually indicating a hardware fault (well in the two faulty units I have looked at).
