License Clarification
2i0jmt
Post by 2i0jmt » Sun Apr 21, 2019 8:25 pm
Hi Folks,
Please forgive me that this isn't specifically related to ATV, but I'm hoping someone can help me.
I noticed this in our license:
"7(6) In order to reduce the likelihood of causing Undue Interference, the Licensee shall
ensure that the Radio Equipment is capable of receiving Messages on the same frequencies
and with the same classes of emission in use for the transmission of Messages by the Radio
Equipment."
What does this mean exactly? There are many projects out there that our transmitters only. Does it simply mean that you should have some device in your shack capable of receiving the same frequency/mode that you are transmitting on?
Conversely, I'm assuming it's ok to have the TX and RX as the same device? (With only either tx or rx occuring at once)
In the case of Oscar-100, I take it I'd need something capable of receive the 13cm uplink signal?
G4IUG
Re: License Clarification
Post by G4IUG » Sun Apr 21, 2019 9:09 pm
Best not to ask ;)
Ex G6ANG/T and G8EAO
Post by G8GKQ » Sun Apr 21, 2019 9:12 pm
In the case of Oscar-100, I take it I'd need something capable of receive the 12cm uplink signal?
Jonny: Yes, Yes and Yes. The MiniTioune DATV receiver will receive at 2400 MHz, so this suffices for DATV. However, for narrowband operation, you do need a narrowband 2400 MHz receiver (not just the Goonhilly WebSDR).
2i0jmt
Post by 2i0jmt » Sun Apr 21, 2019 9:19 pm
Thanks Dave
I was hoping to get a LimeSDR Mini soon for the Portsdown I plan to build, and I'm pretty sure that would fit the bill?
Jonny
