Using SDRconsole on QO100 ATV co-ordination channels
G7JTT
Re: Using SDRconsole on QO100 ATV co-ordination channels
Post by G7JTT » Sat Apr 20, 2019 8:15 am
Can't remember Adrian I'll check later when I finish, sometime around 3pm hopefully.
G7JTT
Post by G7JTT » Sat Apr 20, 2019 2:16 pm
Hi Adrian ok try to set Tx to auto and Rx LNAW then set Tx to a ham band frequency
G4uvz
Post by G4uvz » Sat Apr 20, 2019 5:44 pm
3 steps forward 2 steps back!
Well due to a coughing fit I found that the vox appears to key the Tx!!
So as the Lime I understand works duplex ..I tuned to my tx freq expecting to see a big signal appear!
Nothing appeared! I still can not click on the TX button..and I suspect I may just be seeing the Vox system working
TX Tone Tune and drive being still greyed out...although the TX square does go Yellow when Vox is keyed!
I always felt that the Minitune once mastered was worthy of a good pass at O Level
If I ever hack this it's got to be worth a PHd!Image
Screenshot (39).png (289.85 KiB) Viewed 4560 times
G4uvz
Post by G4uvz » Sat Apr 20, 2019 5:57 pm
A bit more info ..I clicked the record button whilst the vox was keyed but although I could see the audio spektrum bouncing up and down ..the recording was blank
G4KLB
Post by G4KLB » Mon Apr 22, 2019 10:54 pm
If you have a greyed out TX box its normally because 750KHz isn't selected
G7JTT
Post by G7JTT » Tue Apr 23, 2019 11:27 am
Just for info there is a bug in 3.0.7 in that if the TX window is floating TX won't work. So you must have it docked this is to be fixed in the next release.
