3Ghz Vector Signal Generator
G1BVI
Post by G1BVI » Mon Apr 01, 2019 11:11 am
Anritsu MG3700A 3GHz Vector Signal Generator
- Frequency range 250kHz to 3GHz
- Output Level: -140dBm to +19dBm
- Linearity: +0.2dB typ, Switching time <80ms (Normal mode)/<10ms (Continuous mode)
- RF Spectrum Invert Function
- Buil-In dual channel 14bit Arbitrary Waveform Generator with optional 2GByte memory upgrade (512MSamples per channel) for creation of internal I/Q modulation signals
- Internal 120GB SSD for waveform and setting storage
- Built-in CF card reader for transferring data
- Built-in BER Measurement Function for bit rates of 1kbps to 20Mbps
- External Interfaces: 100Mbps Ethernet, GPIB
- Comes with optional mechanical attenuator (which has >70% of its overall service life of 20 Million operations left)
- Comes with latest firmware installed and a copy of the Anritsu IQProducer Windows software on CD
More details can be found here:
https://www.anritsu.com/en-US/test-meas ... ts/mg3700a
https://dl.cdn-anritsu.com/en-au/test-m ... E11500.pdf
The Generator has been manufactured in 2012 and is in very good cosmetical and fully working condition.
Asking price is £1800 ono
