Octagon OQSLG current consumption ?
G4WIM
Post by G4WIM » Thu Mar 28, 2019 8:56 pm
just bought an Octagon OQSLG 4 output LNB and have modified it for a 25MHz ext reference.
It is drawing 140mA at 15V supply - I have it in my head that it only drew 70mA before I modified it - should have written it down....
Seems to work fine though, but was just wondering if anyone knows how much they should draw.
Not much info on the Octagon website or elsewhere.
Regards Tim
g8vpg
Re: Octagon OQSLG current consumption ?
Post by g8vpg » Fri Mar 29, 2019 9:11 am
Tim,
I don't have that particular model, but 140mA is about what my other LNB's draw, so I don't think you've created a problem.
73 Shaun.
Post by g0mjw » Fri Mar 29, 2019 9:42 am
I have one of these. Did you do the permanent V and H modification? In that case you have two parts running so it is about right. If not, it may be oscillating. That can destroy the front end device, it did with the first one I modified. The second is, so far, performing well.
G4WIM
Post by G4WIM » Fri Mar 29, 2019 4:31 pm
Hi Mike,
I only did the external freq ref mod - mainly for narrow band and interestingly I can detect no degradation of the phase noise.
I noticed once I increase the supply voltage above 15.2V the current jumps up by 20mA to 150mA - I expect because its switched polarisation.
That said I'm concerned about the current draw as I suspect it may have doubled ! Hence my question about current.
I may have to install it on the dish and see how it performs - but have a sneaking suspicion I may ave damaged it - doh !
Regards Tim
G3YJZ
Post by G3YJZ » Fri Mar 29, 2019 4:53 pm
I've just checked my unmodified Octagon OQSLG 4 output LNB and it is drawing 132ma @12v , so I think you are ok.
Allan
G4WIM
Post by G4WIM » Fri Mar 29, 2019 4:55 pm
Thanks Allan - phew, strange what tricks memory and old age can play ;-)
mine also draws 130mA at 12V
Regards Tim
G3YJZ
Post by G3YJZ » Fri Mar 29, 2019 5:05 pm
Tim,
Was the mod from the BATC Wiki https://wiki.batc.org.uk/Es%27hail-2_LNBs_and_Antennaes ?
Allan
G4WIM
Post by G4WIM » Fri Mar 29, 2019 5:51 pm
Hi Allan,
yes that was the mod which I followed and it seems to work very nicely - just need to make a 25MHz duplexer to send the ref up the lnb cable.
Regards Tim
