WB transponder engineering tests
Post by g8gtz » Wed Mar 27, 2019 5:24 pm
From AMSAT-DL:
In order to check the AMSAT Antenna performance, Es'hailSat RF Engineering Team will use WB Transponder during the next days for an hour with a constant wave carrier (CW) to perform the steps below.
o Switch OFF DATV-Beacon!
o Raise CW Carrier
o Perform level and saturation check
o Switch OFF CW Carrier
o Bring back Modulated carrier
Please refrain from any transmission during the above tests on the WB transponder - Thank you!
Once the WB DATV-Beacon is back on, you are welcome to use the WB transponder.
