tt s2 3200
m1cdq
tt s2 3200
Post by m1cdq » Thu Mar 21, 2019 2:31 am
just picked up a tt s2-3200 for a fiver. got the tioune software for it installed. but it appears it wont tune low enough for es hail
will it recieve es hail or wont it tune low enough
g8vpg
Re: tt s2 3200
Post by g8vpg » Thu Mar 21, 2019 8:33 am
From memory, this has a standard satellite tuner which tunes 950-2150MHz. A standard LNB with a local oscillator at 9750MHz will produce an output in the 745MHz region, so no, it will not work. However, it is possible to buy LNB's with converted local oscillators which will produce an output in this range - Darko in Austria sells these. An upconverter is another option, but the best option is to use the more up to date USB Minitiouner. The software for this is more advanced and still being developed.
73 Shaun.
