Dual Feed for Prime Focus Dish
g7avu
Post by g7avu » Mon Mar 18, 2019 11:44 pm
Hi All
Apologies if this has already been answered.
I have seen lots of designs on the internet for a dual feed for TX/RX but they have all been for an offset dish.
I have have a 1.7m Prime Focus dish with an f/D of 0.33. The designs online line for the offset dish's have said they could work with a prime focus dish with and f/D no lower then 0.5 which mine is below making these feeds no good.
Does anyone know of any designs for a dual feed TX/RX for a prime focus dish (1.7m f/D = 0.33) which I can make? If there are no dual feed designs I would at least want to find a design for TX into the Prime Dish, I can sort RX separately.
Thanks in advance
Bob
G7AVU
Re: Dual Feed for Prime Focus Dish
Post by g0mjw » Tue Mar 19, 2019 2:20 pm
If it only for TX then a super VE4MA style feed will suffice. You will need to feed it on two ports with appropriate phasing to get the circular polarisation.
http://www.w1ghz.org/antbook/conf/VE4MA ... _feeds.pdf
http://www.ok1dfc.com/eme/emeweb.htm
G4FRE
Post by G4FRE » Tue Mar 26, 2019 10:39 am
The ve4ma superfeed has an inbuilt polariser. One connector gives rhcp, one gives lhcp. Tried the 13cm one I used on eme at the weekend on the narrowband transponder and it works very well.....without a dish!
G4FRE
g7ntg
Post by g7ntg » Wed Apr 10, 2019 10:37 am
to Mike G0MJW - I built the new circular feed as your article in CQ-TV263 but did not fit the horn at the end yet. Without the horn the performance is superb on receive but when I push fitted the short horn in to the end of the waveguide the receive signal strength dropped 8dB! I use a 1.2 metre prime focus dish with a f/d of 0.4 and the focal length is set so that the focus is at the end of the waveguide. The waveguide on my previous square patch antenna protruded 7.14mm (1/4 wave) in front of the patch. the new antenna waveguide protrudes the same amount and the receive sensitivity is within 1 DB of the old one. Am I missing something here? is it the dish illumination that is different? I wonder what dish size the horn is optimal for.
Any ideas would be much appreciated.
dh2va
Post by dh2va » Wed Apr 10, 2019 12:25 pm
I think the horn extension in CQ-TV263 is better suited for shallow dished (f/D 0.6 as described) as it concentrates the lobe more in forward direction (like the dielectric horn). A f/D 0.4 as you have it might want to use a wider beam so leaving both the horn (or the dielectric lens) away should be better suited.
Post by g0mjw » Wed Apr 10, 2019 4:17 pm
That horn is meant for a higher F/D - e.g. 0.6-0.7. It has a gain of 11 dB and a -10dB beamwidth of 100 degrees though not a shaped pattern you get when you add all those ridges you see in LNB horns.
You will want something much smaller for 0.4 F/D. What you are seeing is under-illumination of the dish. The good news is just the waveguide alone is close as you found - so you did not really need to make the second patch. You might gain in efficiency to 65% or so turning the horn to about 27mm diameter. The judgement you need to make is around noise which will be lower for a larger horn. The satellite is so strong anyway with a 1.2m dish you are probably transponder noise floor limited, certainly on narrow-band.
The S-band patch has a gain of about 9 dB, so you will under illuminate a bit. At least the neighbours wifi will continue to work.
